fuel filter
2002 FORD MUSTANG
84,000 MILES • 6 CYL • 2WD • AUTOMATIC
BKB24
where is fuel filter?
Feb 20, 2011 at 3:55 PM
The location of the fuel filter is in the diagrams below here is a guide to help walk you through the steps and a video to show you how to remove the fuel lines.
https://youtu.be/Boi0DPXVHbM
and
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Feb 20, 2011 at 3:59 PM
WRENCHTECH
  • 20,761 POSTS
It's mounted near the tank, under the car. https://www.2carpros.com/images/external/87559136.gif
Feb 20, 2011 at 4:00 PM
BKB24
thanks for the quick response. is this something that should be done by a tech
Feb 20, 2011 at 4:11 PM
WRENCHTECH
  • 20,761 POSTS
Not necessarily but you do need a special tool to get the lines off and watch your eyes with the fuel spray.
Feb 20, 2011 at 4:13 PM
BKB24
Thanks you very much I love this site
Feb 20, 2011 at 4:19 PM
WRENCHTECH
  • 20,761 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Feb 20, 2011 at 4:22 PM
SHIPLEYBSHIPLEY
Where is and how do u change the fuel filter on a 2001 ford mustang gt? Just bought it and want to due some routing maintenance.
Dec 4, 2019 at 12:54 PM (Merged)
https://images.2carpros.com/forum/automotive_pictures/12900_ff_36.jpg
REMOVAL WARNING: FUEL SUPPLY LINES ON ALL VEHICLES EQUIPPED WITH FUEL INJECTED ENGINES WILL REMAIN PRESSURIZED FOR LONG PERIODS OF TIME AFTER ENGINE SHUTDOWN. FUEL SYSTEM PRESSURE MUST BE RELIEVED PRIOR TO FUEL SYSTEM SERVICE TO PREVENT POSSIBLE PERSONAL INJURY OR A FIRE HAZARD. Disconnect the battery. Relieve the fuel system pressure. Raise the vehicle. Disconnect the filter push connect fittings.
https://images.2carpros.com/forum/automotive_pictures/12900_ff1_15.jpg
Unsnap the filter from the bracket and remove. INSTALLATION To install, reverse the removal procedure. https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
DAGIRARD1956
where is the fuel filter located?
MIKE H R
  • 3,094 POSTS
the fuel filter is mounted in line, it is on the passengers side, below the trunk area, next to the fuel tank.
