How to release the tension from the parking brake cable and disengage the cable end from the parking brake lever on the brake caliper.
Feb 4, 2010 at 12:51 PM
AUTOMD
MEMBER
try the steel threaded cable that comes from the back of your hub and is joining a short cable from the other hub--then the original cable runs to a threaded end with an adjuster nut in it--and one smaller nut on the end outside of that--(this is the equalizer bar)--you'll see it real close to your transmission.
Mar 11, 2021 at 2:28 PM
