2000 Ford Mustang clutch
85,000 MILES • 6 CYL • 2WD • MANUAL
BANNISTERR
  • 9 POSTS
the clutch makes noise when idling and the clutch not depressed
Oct 13, 2010 at 4:59 AM
SATURNTECH9
  • 30,869 POSTS
Sound's like you could have a bad throwout bearing you will have to take apart the clutch to see if it's the throwout bearing or something else like the transmission input shaft bearing.
Oct 13, 2010 at 5:05 AM
BANNISTERR
  • 9 POSTS
Hi I already replaced the clutch disc, pressure plate adn throughout bearing about 2 years ago so it doesn't seem like it should be going out again, but then this could be possible since I didn't replace it with OEM parts I used Napa. Any other suggestions?
Oct 13, 2010 at 6:37 AM
SATURNTECH9
  • 30,869 POSTS
It sound's like you have a bad throwout bearing or a bad input shaft bearing in the transmission.Without getting in there one can only guess what's going on.
Oct 13, 2010 at 6:56 AM
BANNISTERR
  • 9 POSTS
Sounds about right....Thanks :)
Oct 13, 2010 at 8:06 AM
