2000 Ford Mustang clutch
BANNISTERR
  • 2000 FORD MUSTANG
  • 6 CYL
  • MANUAL
  • 85,000 MILES
The clutch makes noise when idling and the clutch not depressed
Wednesday, October 13th, 2010 AT 11:59 AM
SATURNTECH9
  • 30,869 POSTS
Sound's like you could have a bad throwout bearing you will have to take apart the clutch to see if it's the throwout bearing or something else like the transmission input shaft bearing.
Wednesday, October 13th, 2010 AT 12:05 PM
BANNISTERR
  • 9 POSTS
Hi I already replaced the clutch disc, pressure plate adn throughout bearing about 2 years ago so it doesn't seem like it should be going out again, but then this could be possible since I didn't replace it with OEM parts I used Napa. Any other suggestions?
Wednesday, October 13th, 2010 AT 1:37 PM
SATURNTECH9
  • 30,869 POSTS
It sound's like you have a bad throwout bearing or a bad input shaft bearing in the transmission. Without getting in there one can only guess what's going on.
Wednesday, October 13th, 2010 AT 1:56 PM
BANNISTERR
  • 9 POSTS
Sounds about right. Thanks :)
Wednesday, October 13th, 2010 AT 3:06 PM
