2000 Ford Mustang
130,000 MILES • 6 CYL • 2WD • MANUAL
KESHIA79
Hello I just install a new fuel pump in my mustang and I can't seem to get it to start I has GPS tracking on it I was wondering will the GPS tracking have anything to do with it not starting or does my problem lay else where can you please give me an idea where to start because I have tried everything possible to get this car started.
May 12, 2010 at 7:02 AM
BMRFIXIT
  • 19,053 POSTS
lets try and start from the beginning
engine crank but will not start
turn key on ,do you have check engine light on you should if not check fuses ,relays ,wiring and ignition switch
do you have security light on and blinking if so check for codes if not
open hood and check for spark
have a helper crank engine for you as you check for spark
if have spark check for fuel and fuel pressure
no fuel check fuses and relays
check if inertia switch was tripped
May 12, 2010 at 1:04 PM
