2000 Ford Mustang
53,000 MILES • 6 CYL • 2WD • AUTOMATIC
TERRY WEIKERT
Service engine soon light came on , left code 401
Dec 3, 2008 at 7:26 AM
DAVE H
  • 13,383 POSTS
70) Continuous Memory DTC P0401: Perform KOER Self-Test
This DTC indicates EGR MONITOR failed due to PCM detecting EGR flow while driving is less than desired minimum. Possible causes for this fault are:
EGR valve stuck closed.
EGR valve diaphragm leak.
EGR flow plugged or restricted.
Faulty EGR hose.
EVR VPWR Circuit Open
EVR VPWR Circuit To PCM Open Or Shorted To PWR
DPFEGR Sensor VPWR Circuit Open
Faulty DPFEGR Sensor Hoses
Faulty EGRVR Solenoid
Faulty PCM
If fault is currently present, KOER DTC P1408 should be present. Perform KOER ON-DEMAND SELF-TEST. If DTC P1408 is present, go to next step. If DTC P1408 is not present, go to step 90).
Dec 3, 2008 at 12:28 PM
