1999 Ford Mustang turn signals
CRUSHERTRUCK
Electrical problem
1999 Ford Mustang V8 Two Wheel Drive Automatic
Do I have to take the trunk apart to change the rear turn signals?
May 29, 2009 at 3:55 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Are you replacing the bulb or the taillamp assembly?
May 29, 2009 at 8:29 PM
CRUSHERTRUCK
just the bulb
May 30, 2009 at 1:29 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Okay, in the trunk detach the clips holding the finishing panel on. Then remove the retaining nuts securing the housing. Pull the tail light assembly outward enough to be able to reach and turn the bulb 1/4 turn then remove it.
May 30, 2009 at 6:19 AM
