1999 Ford Mustang Shaking or Wobbling Steering Wheel
1999 FORD MUSTANG
38,000 MILES • V8 • 2WD • MANUAL
JEWDAMAN2001
Just here recently I have noticed that my steering wheel has a slight wobble both while driving at normal speeds and at the start of braking, it was also pulling to the right but after correcting the air pressure in all tires this stopped. What could be causing the steering wheel to wobble?
Aug 30, 2009 at 10:16 PM
  • CAR REPAIR CONTRIBUTOR
  • 31,937 POSTS
Hi there, If you have a vibration under braking this will be a brake rotor problem, they can be machined if they are with in thickness limits, otherwise get a wheel balance done and have the steering & suspension check for worn components.
mark (mhpautos)
Aug 31, 2009 at 9:13 AM
