1999 Ford mustang passenger window
BRYAN23UH
I have a 1999 Ford Mustang V6 coupe. The passenger window recently went out with no warning. Neither the switch on the driver's side door or the passenger side door will raise or lower the window. However the driver's side window works fine as well as the locks on both sides. I thought it may be electrical but the lock switch works and the driver's side window is working fine. What could be the problem?
Sep 25, 2007 at 10:58 AM
BRYAN23UH
weirdest thing happened...the same day I posted this problem I got back in my car about three hours later and the window was working fine. I haven't had any problems as of yet. Do you think it could be a wiring problem or maybe the switch starting to go out?
Sep 26, 2007 at 10:03 AM
