1999 Ford Mustang heater problem
160,720 MILES • 6 CYL • 2WD • MANUAL
BRANDON R
my heater blows nothing but cold air i turn it on for 20 min and all it does is blow cold air in the morning what is my problem how can it be fixed
Oct 19, 2010 at 4:38 PM
WRENCHTECH
  • 20,760 POSTS
With the engine at full operating temp, locate the 2 heater hoses where they go into the firewall and feel them to see if they are both hot to the touch. If they are..........
The temperature is controlled by the use of an air mix door that is operated by an electric motor/actuator. This door can be jammed or the actuator can be inoperative or have stripped plastic gears internally.
Oct 20, 2010 at 12:19 AM
  • 75,988 POSTS
Start by replacing the thermostat and check the heater core if its clogged-up, heater control valve and the air blend door
