1999 Ford Mustang heater problem
BRANDON R
  • 1999 FORD MUSTANG
  • 6 CYL
  • MANUAL
  • 160,720 MILES
My heater blows nothing but cold air I turn it on for 20 min and all it does is blow cold air in the morning what is my problem how can it be fixed
Tuesday, October 19th, 2010 AT 11:38 PM
WRENCHTECH
  • 20,761 POSTS
With the engine at full operating temp, locate the 2 heater hoses where they go into the firewall and feel them to see if they are both hot to the touch. If they are.
The temperature is controlled by the use of an air mix door that is operated by an electric motor/actuator. This door can be jammed or the actuator can be inoperative or have stripped plastic gears internally.
Wednesday, October 20th, 2010 AT 7:19 AM
Start by replacing the thermostat and check the heater core if its clogged-up, heater control valve and the air blend door
