1999 Ford Mustang headlamps
144,000 MILES • 6 CYL • FWD • AUTOMATIC
RHERDMAN1
my head lamps have recently quit working on me at first i thought it was the bulbs so i replaced them and they still do not work, i then went and changed all the fuzes, but still nothing i think it is the light switch inside the car. could this be the problem? and how can i fix this?
Nov 17, 2008 at 4:45 PM
TEAG
  • 158 POSTS
That very well could be the problem. New switches are inexpensive. They are fairly easy to replace. It just requires some dash cover removal. Im not sure if your local autoparts store carries them but I do know you can order them online for anywhere between $30-$40. Good luck. Hope this helps you out.
Nov 19, 2008 at 3:08 AM
