1999 Ford Mustang battery runs dead when sitting
34,500 MILES • V8 • 2WD • MANUAL
RYDNKITTY
My mustang has less than 35000 miles. When I do not drive it the battery runs dead. Usually it will only sit for a week or two when this happens. I bought it a year ago and it only had 4000 miles in it, it sat in a garage in Hawaii for 8 years. My experience with this issue is that it is usually the voltage regulator that causes this.I have owned a few older Mustangs but I am unfamiliar with this year, where do I find the voltage regulator on this model??
Jul 19, 2010 at 3:07 PM
  • 75,988 POSTS
Lets do this put a test lite between the negative cable and the negative battery post if the test lite lits you have a short circuit in the electrical system now disconnect the alternator if the test lite remains lit, its not coming from the alternator. Do below battery drain test
https://images.2carpros.com/forum/automotive_pictures/12900_parastic_draw_1_231.jpg
Jul 19, 2010 at 10:02 PM
