1998 Ford Mustang upper radiator hose too hot
DSECRETONEG
Engine Cooling problem
1998 Ford Mustang 6 cyl Two Wheel Drive Manual 100k miles
upper radiator hose gets too hot.i replaced water pump,upper & lower radiator hoses,thermostat,radiator.
Mar 19, 2009 at 5:20 PM
  • 75,988 POSTS
Did you bother bleeding the cooling system for air lock if not do it and see what happens. also check the water pump do below
One way to test for a bad water pump is to squeeze the upper radiator hose when the engine is hot and idling. Careful, because the hose will be HOT! If you do not feel much coolant circulating through the hose when you rev the engine, the pump may be bad. The other cause might be a bad thermostat that is not opening properly (remove and inspect the thermostat), or a clogged radiator.
Mar 19, 2009 at 5:31 PM
