1998 Ford Mustang Transmission problem
15,000 MILES • 6 CYL • 2WD • AUTOMATIC
TAWHITE43
I"m looking forward to buying a used 1998 Foed Mustang. However, the seller syas that the car has a transmission leak by the rear seal on the driver's side. How much would it cost to have this repaired?
Feb 25, 2009 at 7:33 AM
  • 31,937 POSTS
HI there, if this is just a drive shaft seal, that is not a big problem, but with out seeing this first hand i can't make a definite diagnosis, if the seller is genuine, then there should not be a problem asking them if you can get this leak inspected and reported on first hand, this will give you a true indication as to the problem, but if it is just a seal, you should be able to fix it for well under $150.00 i would say.
mark (mhpautos)
Feb 25, 2009 at 7:40 AM
