1998 Ford Mustang sputtering & cabon smell
84,281 MILES • V8 • 2WD • AUTOMATIC
GROLEAD1
my 98 mustang gt sputters & i detect carbon smell from my exhuast , replaced all o2 sensers maf senser spark plug wiring, spark plugs & fuel filter on it already can you tell me what is causing this & how i can fix it.
Sep 6, 2010 at 1:33 PM
  • 31,937 POSTS
Hi there,
Pull the plugs and check for one sooty dirty plug, if only 1 is dirty check the injector if all are fouled you will have a problem with the TPI or map sensor/air flow meter, a scan may give you a code for a fault as well.
mark (mhpautos)
Sep 6, 2010 at 2:10 PM
