1998 Ford Mustang Smell Fuel
63,000 MILES • V8 • 2WD • AUTOMATIC
MCCAULLEYKC
I smell raw fuel at engine idle and it's real strong, I looked under the car but don't see any leaks but when you pop the hood you can tell there's definetly an issue.
Jun 28, 2008 at 11:38 AM
MUSTANG87
  • 261 POSTS
look around and on fuel injectors and fuel rails for gas leak.if leaking alot you will se a pudle od definitely wet injector or on fuel lines rails etc.also check it with engine running ,use a flash light to spot it easier.good luck
Jun 28, 2008 at 12:18 PM
