1998 Ford Mustang Passenger side door damaged and won't ope
79,350 MILES • 6 CYL • 2WD • MANUAL
DGRIMSEY17
i had a blow out and bent my tire rod when hitting a curb, I replaced that and my door won't open. It opens a little bit and then hits the side panel. How much would it cost to get it fixed?
Jun 25, 2008 at 5:38 PM
BLACKOP555
  • 10,386 POSTS
for the meantime you can use a screwdriver to separate the pannels to open the door, the door will probably have to have the hinges loosened and pulled back a hair to make up for the adjustment, or the panel will have to be loosened and pushed forward.
shouldnt be no more then 100 bucks.
Jun 26, 2008 at 1:30 AM
