1998 Ford Mustang Fuses blowing
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
TIMBEES
Fuse #1 block blows when starting car..takes out numerous functions including turn sigs.. Can u help me???
Mar 7, 2009 at 10:26 AM
RACEFAN966
  • 5,029 POSTS
Well if I read the wiring diagram right that is your instrument cluster fuse. If this is true and you have a digital multi meter then get back to me and we do a couple of tests to see if you cluster is bad. If need be get back to me via private message ok.
Mar 9, 2009 at 11:13 AM
