Fuel filter
SHEENALYNN34
  • 1998 FORD MUSTANG
  • 6 CYL
  • 150,000 MILES
I need to know where the location of my fuel filter! I just had a fuel filter and pump replaced and now it wont even start. If u prime the throttle body it starts for a second until that gas is gone, then dies ! Im not even sure if the mechanic I used even changed them, it also hesitates taking gas while driving it real bad now(since I changed those) it has never done that before. Any suggestions or advice! I need help bad.
Saturday, April 24th, 2010 AT 5:50 PM
WAKELAX17
I know that on my 97, the fuel filter is just on the other side of the gas tank itself, if you put up the back end of your car and slide under, it's right in the middle on the other side there.
Saturday, May 1st, 2010 AT 5:02 PM
GLADE 265
  • 1995 FORD MUSTANG
  • 6 CYL
  • MANUAL
  • 124,891 MILES
Seems to not be getting enough gas when under a load. Misses. Where is fuel filter located.
Wednesday, December 4th, 2019 AT 8:55 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Your fuel filter is located in front of the fuel tank, near the rear axle.
WIZZAP
  • 31 POSTS
You should be able to remove it with a flat head screwdriver If your happen to have the snap on line type you will need a special line tool they are like 5 bucks at parts store
BENNIE0711
  • 1991 FORD MUSTANG
  • 4 CYL
  • 250,224 MILES
Where is the fuel filter located, and how is it changed?
INTERNETMECHANIC
  • 700 POSTS
My info shows it is located under the vehicle, passenger side, close to gas tank, mounted on frame rail. You need to make sure there is no pressure on the fuel system, before taking anything loose. Usually after the vehicle sits overnight without the pump being activated, not much pressure, but, you still need to be aware. Gas will still probably run out of the line/s, don't lay anything electrical where gas can hit it. If you loosen the cap, sometimes that helps to keep gas from running out? If too much gas is running out plug the line, till your ready to go back with filter. You'll probably need a disconnect tool to take fitting loose from filter, The autostore sells it. The filter looks like the picture.
https://www.2carpros.com/forum/automotive_pictures/512072_mustang_fuel_filter_1.jpg
STEVE NUTTALL
  • 1988 FORD MUSTANG
  • V8
  • MANUAL
  • 94,000 MILES
Where is the fuel filter located?
BLUELIGHTNIN6
  • 16,542 POSTS
Under vehicle, passenger side, below seating area, front of fuel tank, mounted on frame in fuel line.
Thanks for using 2CarPros. Com!
