1998 Ford Mustang front disc pad replacement
1998 FORD MUSTANG
RUSSEN58
Brakes problem
1998 Ford Mustang 6 cyl Two Wheel Drive Automatic
how do i replace the front disc pads on a 1998 mustang?
Apr 18, 2009 at 4:41 AM
MERLIN2021
  • 17,250 POSTS
remove the two mounting pins, one at the top, other at the bottom of the caliper, take cap off master and just let it sit on top of it, then push the piston back into the bore, use either large channel lock pliers, or a "C" clap large enough to do the job, but place a used pad against the piston if using the C clamp, you dont want to break the piston, isntal is reverse proceedure, once the calipers are re-mounted, put master cyl cover back on, then slowly pump the pedal until firm. this pushes the pistons out and seats the pads against the rotor.
Click on this for some visual aid!
http://www.2carpros.com/how_to/how_to_replace_brakes.htm
Apr 18, 2009 at 4:49 AM
