1998 Ford Mustang engine noise
1998 FORD MUSTANG
110,000 MILES • 6 CYL • 2WD • MANUAL
BOGONE
  • 8 POSTS
98 Mustang, 3.8L, 5 spd, 110k
Engine makes a hipitched intermittent squeal from the front of the engine. It makes same sound with belt removed. Have replaced everything. Good oil pressure, uses a chain for driving camshafts. Checked pvc system.
Charlie
Feb 21, 2009 at 5:27 AM
GAP10287
if your car was coil packs, you might have a cam sensor where the distributor would normally be. this sometimes makes a similar noise
Feb 22, 2009 at 8:35 AM
