1998 Ford Mustang blown # 1 fuse in fuseblock
TIMBEES
  • 1998 FORD MUSTANG
  • 4 CYL
  • 137,000 MILES
I am blowing # 1 fuse in this fuseblock repeatedly. It blows when the car is started.I know this fuse handles quite a few items. Can u help me/?
Tim
Wednesday, September 10th, 2008 AT 2:22 PM
TURNEDWRENCH
  • 13 POSTS
This one may take you a while but it will save you alot opposed to taking it in and having it done. Figure out everything that is run threw this fuse disconnect them one by one and using a volt meter test each connector. They should all have around the same voltage on the hot wires, if any of them is lower voltage then that wire is opening the circuit and you will have to find where its grounded out.
Tuesday, September 16th, 2008 AT 6:44 PM
