1998 Ford Mustang
MAXPOWERS
  • 1998 FORD MUSTANG
Shakes or Wobbles problem
1998 Ford Mustang 6 cyl Automatic
Ok so I have this problem with the steering once I hit 45-48mph the steering wheel start to shake badly and I just got the alignment done and it stoped about 50% of the shaking but still conserns me.
Wednesday, April 1st, 2009 AT 7:04 PM
BLUELIGHTNIN6
  • 16,542 POSTS
If you had the front and rear suspension aligned and it is still shaking I suggest having the tires inspected. If one or more of the tires are low on air, damaged internally/externally, or is missing a balancer then it will cause vibrations at highway speeds that will be felt through the steering wheel.
Thanks for using 2CarPros. Com!
Wednesday, April 1st, 2009 AT 8:20 PM
