1997 Ford Mustang Oil pan gasket replacement
1997 FORD MUSTANG
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
MUSTANG4LIFE
okay i got a 97 ford mustang, and the oil pan gasket is leaking...i was told that i would have to lift the motor several inches in order to reach the oil pan gasket...is this true? and if it isnt, is there a way for somone with basic mechanical knowledge to replace the oil pan gasket without any MAJOR tools?
Sep 24, 2009 at 8:18 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes it is true. You must install an engine support and lift eyes to raise engine properly in order to replace oil pan gasket.
Sep 24, 2009 at 2:18 PM
