1997 Ford Mustang Lower intake manifold gasket replacement
210,000 MILES • V8 • 2WD • AUTOMATIC
BRENT BONHOMME
On my 97 GT the intake manifold has a upper and a lower gasket. My lower gasket is leaking where it is attached to the head at the back side of the engine. Do I need to replace both upper and lower gaskets or can I just replace the lower one. Also what would be the easiest way to replace the gasket, any tricks?
Feb 24, 2009 at 1:58 AM
RANGERDANGER17
  • 224 POSTS
i dont know any tricks but i do know you only have to replace gaskets you take off so if you remove it you have to replace it
Feb 25, 2009 at 11:09 AM
