1997 Ford Mustang Fan Relay
1997 FORD MUSTANG
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
MUSTANG1997
I am trying to locate my rad fan relay and I cant find it. what is going on is that when you hook up the fan sensor up (its a new sensor) the fan will not come on, but when u unhook it then it starts running and it will run without stopping at all. Of course my check engine light stays on as well, but I have no idea where the fan relay is to change it or if that is even the problem. I don't have a manuel to check or anything because I got it used and one didnt come with it. I need help in this matter asap. thanks
mustang1997
Jan 12, 2010 at 9:57 AM
JDL
  • CAR REPAIR CONTRIBUTOR
  • 16,098 POSTS
Welcome to the forum, may be a relay module instead of separate relay? Located behind the engine coolant reservoir. Have the trouble codes checked, some of the national brand autostores used to check codes for free. You can call and ask.
I just wanted to add the motorcraft site, www.motorcraft.com, should have some owners manuals. When the page comes up, click on the technical resourses link, at the top. On that page, in th left column, should be a link for owners guides/ owner manuals, something like that. They ask for year /make/model, you'll just have to look and see what they have.
Jan 12, 2010 at 10:26 AM
