1997 Ford Mustang fan problem
63,000 MILES • V8 • 2WD • AUTOMATIC
DBDAVIS
the coolant fan on my car does not work. i turn the a/c on it runs cool for about 30 seconds it keeps running but it turns hot, smoke pours out from where you pour coolant in and the gauges go nuts inside the car the voltage goes low and the temperture goes up.
Aug 22, 2010 at 11:15 AM
BLUELIGHTNIN6
  • 16,542 POSTS
so you mean the only time cooling fan comes on is when you turn A/C on? if so check for faulty engine coolant temp. sensor.
Aug 22, 2010 at 11:36 AM
