1997 Ford Mustang 97 cobra thermostat/pulleys
86,000 MILES • V8 • 2WD • MANUAL
KPHOGAN89
I was having problems with my cooling fan coming on and i thought that was the problem. I hard wired it and its still overheating. I'm pretty sure i have the thermostat in right? (Spring pointing left). I also did the pulleys and belt at the same time. If the belt's slighty too big would that cause it to overheat? New radiator, thermostat, and coolant sensor.[img:6eca4c7516]http://www.2carpros.com/forum/automotive_pictures/210095_cobra_002_1.jpg[/img:6eca4c7516]
Jul 6, 2008 at 4:43 AM
2CARPRO JACK
  • 11,533 POSTS
Does it overheat while driving or sitting still or both? Is this engine supercharged? If it overheats all the time, have it chemical tested for a blown head gasket. When t-stat is open (hot) can you see the coolant flowing in the radiator?
Jul 8, 2008 at 12:41 AM
