AOD transmission and 302 thermostat housing
EVERETT HOBBS
  • 1930 FORD MUSTANG
I have an AOD transmission and 302 engine out of a 1985 t-bird I put in a 66 mustang. Cant get tranny lines to come out of fittings going in to case. They leak very bad. I have new fittings with plastic insides but need to know if there is a tool or trick to seperating. Also having bad luck with thermostat housing on manifold. Have tried gaskets 2 times and different silicones with no luck. I must be overlooking something. Can you please help
Thursday, May 10th, 2007 AT 5:21 PM
2CARPRO JACK
  • 11,533 POSTS
Yes, I believe there is a special release tool. Local auto parts house might have them. I use general trim adhesive to hold the gasket in place, silicone can cause the gasket to squirt out when tightened
Thursday, May 10th, 2007 AT 6:15 PM
