Could be a faulty VSS (vehicle speed sensor). Does the trans shift properly? If so the VSS may be ok and it is a problem in the dash or wiring. The VSS has to be sending a good signal to the PCM for it to shift the trans properly, if the VSS is the issue, the trans most likely would be shifting erratic as well
SPONSORED LINKS
Thursday, August 21st, 2008 AT 7:52 AM
