1996 Mustang Clutch
MONTYCHUCK
Does anyone know how to adjust the clutch on a '96 Mustang? Put new clutch in, but it is too tight.
Dec 9, 2006 at 12:45 PM
CARUNDELL
  • 602 POSTS
[quote:7b5e2d857c="montychuck"]Does anyone know how to adjust the clutch on a '96 Mustang? Put new clutch in, but it is too tight.[/quote:7b5e2d857c]
Hey monty,
Too tight as in hard to push? Or too tight as in pedal too close to the floor when clutch engages? If the clutch is hydaulic there would be no adjustment (but you can "modify" the slave cylinder push rod, but I don't recommend it) If its cable operated then adjustment should be provided at either the trans end or pedal end of the cable.
Regards,
Chris
Dec 9, 2006 at 9:10 PM
MONTYCHUCK
Thanks for the reply. It loosend up after working it a few times. :)
Dec 10, 2006 at 9:44 AM
