1996 Ford Mustang Stuck in 1st gear
13,000 MILES • V8 • 2WD • MANUAL
SPRCHRGEDSTANG
I took off a little hard in 1st gear and I shifted into second but the car just revved up when I gave it gas. Well now the car is stuck in first gear. The clutch is working fine. I can drive it around in first gear but it won't actually go into another gear, and when I do move the shifter there is no resisitance at all. Almost like it's loose. My brother and I took the column apart and took the top of the transmission off because he was thinking maybe a linkage or something but we didn't see anything and we also made sure that the little ball at the end of shifter was still in the joint or cup or whatever you would call it. I need help please.
Oct 14, 2010 at 1:12 AM
BLACKOP555
  • 10,386 POSTS
with the trans on the top off can you pop the shifter into neutral by hand with a screw driver?
when using shifter is it actually moving the "cup" to new positions or does it stay in the 1st position.
sometimes the end of the "ball" wears and it wont move the "cup" right due to the wear and when pressure is applied it just pops out
Oct 17, 2010 at 3:27 AM
