1996 Ford Mustang Oil screen
BOBSTEVENSBOB
Engine Mechanical problem
1996 Ford Mustang 6 cyl Two Wheel Drive Automatic
My car can't seem to pump oil to the valves (at least, it may not be getting oil anywhere.) The engine is a 3.8L. Is a clogged screen a possibility? If so, does the engine need to be lifted for that? The VIN # is - 1FALP4040VF158836
Apr 29, 2010 at 2:32 AM
BLUELIGHTNIN6
  • 16,542 POSTS
a dirty oil screen, bad pick-up tube or weak oil pump can all cause low oil pressure. the engine will need to be slightly lifted to remove the oil pan and access the screen, pump and tube.
Apr 29, 2010 at 5:58 PM
RUMREDRUN
  • 12 POSTS
If you can get your hands on a small bore scope drain the oil insert bore scope in the drain hole and look at the pickup screen! I ordered a Tiny Bluetooth bore scope for diagnosing such problems!!
Apr 21, 2019 at 3:00 PM
