1996 Ford Mustang engine makeing knocking sound
J.BEAR
Noises problem
1996 Ford Mustang 6 cyl Two Wheel Drive Manual
my friend was doing burnouts in my 96 ford mustang and now its tapping pretty loud when i gas and goes away when it idols. i checked the rods to see what they looked like but they looked normal so what do u think it could be
Jun 2, 2009 at 8:28 PM
  • 31,937 POSTS
Hi there,
is the tapping coming from the rocker cover? if so i would be thinking a failed lifter, was the engine over revved?
Mark (mhpautos)
Jun 2, 2009 at 8:41 PM
J.BEAR
Hi there,
Mark (mhpautos)
um ya it sounds like its coming form there and yes it was prolly over revved
Jun 9, 2009 at 8:22 AM
  • 31,937 POSTS
Hi there,
I would be thinking a failed lifter,
Mark (mhpautos)
Jun 9, 2009 at 10:14 AM
J.BEAR
so how much do u think that will cost to be repaired
Jun 9, 2009 at 1:22 PM
  • 31,937 POSTS
Hi there,
this is unknown untill you have a look, it may be a lifter,or a bent push rod even, bent rocker posts, over revving a stock engine is not the best thing to do, so you best lift the lid, pull the rocker gear and start with checking for a bent push rod, I'll give you a hint, roll them on a sheet of glass, this will show you if they are bent.
mark (mhpautos)
Jun 9, 2009 at 11:31 PM
