1996 Ford Mustang Coolent flushing
1996 FORD MUSTANG
BILL HESTAND
1996 Ford Mustang 4 cyl Two Wheel Drive
how to flush the radiator and engine block? Is there a freeze plug on the radiator?
Diagram please
Feb 7, 2009 at 4:38 PM
MIKE H R
  • 3,094 POSTS
there is no freeze plug in the radiator, to back flush the system you can get a kit from most automotive stors or just drain the system and then use a hose to back flush the system, Note that the thermastat should be removed to make a better flush. check our link on the left, How does it work and look up cooling it will expalin the cooling system
Feb 16, 2009 at 9:30 AM
