1996 Ford Mustang Clutch for Schwarzenegger
155,000 MILES • 6 CYL • 2WD • MANUAL
ACHILLES7LS
I have purchased a 1996 Mustang. Its a V6 with 5 speed manual transmission. It drives good, runs good. The engine was rebuilt prior to my purchasing it. My only complaint is it seems the clutch was specially install for the Governator himself. I swear after a couple of months of driving it my left leg is larger than the right.
Is this normal, is there any adjustments that can be made? How would I go about doing it. Someone mentioned that it may have a hydrolic clutch instead of cables. When I look under the dash at the pedals I see no cables. I do see a large plastic arm that moves with the clutch, and large spring around the bar the clutch pivots around.
Thanks for any help.
Jun 24, 2009 at 7:31 AM
RACEFAN966
  • 5,029 POSTS
Ok can you contact the prior owner to see if they replaced the clutch when they did the engine? If so what clutch did they use. I have a 98 Mustang with the 5spd and it is smooth as for the clutch. Get back to me with what you find.
Jun 25, 2009 at 2:26 AM
