I replaced the compressor with a new one, accumlator/dryer, clutch cycling switch, the control switch on the dash, and it is still not kicking the compressor on. The compressor worked for about 2 hours blowing cold air, then it quit. You can get the compressor to kick on whenever you jump it at the clutch cycling switch connector that goes back the control switch. The fuses are all okay. Is there any relays that could be bad? What else can I do?
Thanks.
SPONSORED LINKS
Saturday, June 28th, 2008 AT 4:31 PM
