1996 Ford Mustang
NATASHA11982
  • 1996 FORD MUSTANG
Engine Mechanical problem
1996 Ford Mustang 6 cyl Front Wheel Drive Manual
My 1996 Mustang started making a puttering noise today. What could be wrong with it?
Saturday, April 18th, 2009 AT 12:13 AM
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Saturday, April 18th, 2009 AT 5:37 AM
