I replaced the TPS with a new one from Ford. I still have the same problems. I still have code 122 showing -"TP sensor circuit below minimum voltage". And now I cannot clear the code from the computers memory. Additionally, the Check Engine light remains on when driving. Idle is still a problem. Too high, especially after starting the engine when warm. Also, between shifts, RPM drops abruptly. Not smothly as it once did.
There is also a problem when attempting the KOER test. My code reader says that the vehicle is not responding. I checked my code reader to make sure it was confugured properly and tried again. I was able to get codes 122 and 998 -("Hard Fault Present"), before my code reader could no longer function due to the "Vehicle not Responding" prompt.
Short of taking the car to the dealer, I am completely stumped by the cars problems. HELP!
Tuesday, May 15th, 2007 AT 7:55 PM
