1995 Ford Mustang window repair
105,000 MILES • 6 CYL • 2WD • MANUAL
VOHTB
i was using my window when it fell off the track now the window track is where my window was and the glass window fell inside the door. please help it appears my motor was working just fine...appears it got loose from the track now its not working
Dec 26, 2008 at 11:22 PM
DAVE H
  • 13,383 POSTS
you will have to strip the door panel (inner trim) off the door to see why it has come off ?
POWER WINDOW MOTOR
Removal
Raise window to full up position (if possible) and support. Disconnect battery negative cable. Remove inner door trim panel and protective cover. Unplug harness connector.
Remove 2 forward regulator mounting plate rivets. Remove 3 electric motor mounting screws (or rivets). Push regulator mounting plate outward to remove motor.
Installation
Assemble window drive motor to regulator assembly. Tighten motor-to-regulator bolts until snug, do not fully tighten. Connect wiring to motor.
Connect negative battery cable. Operate window to ensure proper gear engagement. Tighten motor-to-regulator bolts to 50-84 INCH lbs (5.6-9.5 N.m). Install door panel and trim.
Dec 26, 2008 at 11:49 PM
VOHTB
it appears that the window became unglued from track poor engineering problem. can you reccommend some epoxy i can use to reglue this window to the track...
Dec 27, 2008 at 12:15 AM
