1995 Ford Mustang water pump rotation
138,000 MILES • V8 • 2WD • MANUAL
MIKE8066
OK, I'm baffled. The fins in my water pump are curved, creating a "scoop", but they turn the opposite direction (back of fins moving forward). Is this correct? I have a 95 mustang 5.0 V8. The water pump runs counter clockwise due to the serpentine system (engine runs clockwise). I have checked every auto part store and the replacement pumps are all the same as mine.
NAPA says their's is a "clockwise" rotation, but one I found on AmericanMuscle.com that is listed as "Reverse-rotation: Counterclockwise"...but they are the SAME water pump!
I find it hard to believe that EVERY part store has the wrong water pump. Are the fins supposed to run with the back of the fin pushing against the water?
[img:ada99ef7b5]http://www.2carpros.com/forum/automotive_pictures/529064_napacw_1.jpg[/img:ada99ef7b5]
[img:ada99ef7b5]http://www.2carpros.com/forum/automotive_pictures/529064_americanmuscleccw_1.jpg[/img:ada99ef7b5]
May 19, 2010 at 12:04 AM
BLUELIGHTNIN6
  • 16,542 POSTS
You need the reverse rotation - opposite of crankshaft type water pump. The pic I attached is correct as well as your pics. I believe NAPA simply has an error in their system, their picture is correct but it should say "counter clockwise" . I have checked several part stores online and all have the same style of water pump, counter clockwise, for the 5.0L . the 3.8L engine, however, does use a clockwise style water pump, but it looks like the second pic I posted below.. Counter Clockwise for 5.0L
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2216.jpg
Clockwise for 3.8L
https://images.2carpros.com/forum/automotive_pictures/261618_713092_1.jpg
May 19, 2010 at 4:53 PM
