Where is the thermostat located and how difficult to remove?' On the engine side of the radiator hose?
Friday, July 16th, 2010 AT 1:23 PM
JASONLEWIS6987
MEMBER
FOLLOW THE UPER RAIDIATOR HOSE TO THE BLOCK(BIG HOSE ON TOP) DISCONECT IT THERLL BE A SMALL HOSE NEXT TO THAT DISCONECT THAT THEN UNSCREW THE TWO BOLTS PULL THE HOUSING OFF AND THATS IT MAKE SHURE YOU KEEP THE THERMOSTAE FACING THE CORECT WAY HOPE I HELPED
