1995 Ford Mustang oil pressure dropping
135,000 MILES • V8 • 2WD • AUTOMATIC
ELDERSTANG
My daughters mustang starts and runs great for about 15 minutes, then at 1000 rpm or lower the oil pressure drops to 0 and the car stalls out. It takes a while to get it started back up, but when it starts, if you keep it above 1500 rpm, it has very good oil pressure. The motor was just rebuilt, and only has about 20k on it. Does the car automatically shut down if the oil pressure drops? Or do i have another problem?
Oct 31, 2008 at 6:13 PM
BLACKOP555
  • 10,386 POSTS
the fuel relay should be wired trhough the oil pressure switch, when pressure drops shuts it off that way it doesnt ruin the engine.
i would be checking to see if the oil pressure sending unit is functioning properly. may need a new pump or differnt oil
Nov 1, 2008 at 2:07 AM
