1995 Ford Mustang Loud Pop in Front Driver Side Suspension
175,000 MILES • 6 CYL • 2WD • MANUAL
MLSTICAL69
HI. WHen I am pulling out or every one in a while Changing gears at lower speeds I get a loud pop from my Drivers Side Front Wheel area!!! \
I replaced the Strut thinking it was related but did not help. Any Ideas? Thanks
Sep 30, 2010 at 11:28 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Was strut mount bearing replaced? Ball joint checked ? Lower control arm bushing checked?
Let me know
Thanks for donate
Oct 1, 2010 at 2:52 AM
MLSTICAL69
Yes The Control arm bushings, Ball joint were both replaced. I am thinking it may be coming from my tie rod, inner or outer.
The strut mount was in good shape too.
Oct 1, 2010 at 12:32 PM
DOCFIXIT
  • 18,828 POSTS
Check out sway bar and links look for rubber mounts missing
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_634.jpg
Also see if spring insulator is deteriated
Oct 2, 2010 at 5:29 AM
MLSTICAL69
Sorry but all is in good condition except for there is a single split in the sway bar bushing. The one that is the stabilizer sits in (Mounted to) Not the link
Oct 2, 2010 at 5:43 AM
