1995 Ford Mustang flywheel replacement
102,000 MILES • V8 • 2WD • MANUAL
ZEROPS
I am replacing the flywheel on this engine does it make any difference as to how it goes on with the counter balancing. Since the new flywheel is not marked to match the crankshaft
Dec 25, 2007 at 4:42 AM
  • 31,937 POSTS
The flywheel is independently balanced so it can go on any way, just be aware that some flywheels have off set mounting bolts, so the fly wheel may only bolt on in one position anyway. If the bolts line up in all positions, it wont matter.
Mark (mhpautos)
Dec 25, 2007 at 9:04 PM
