while accelatating the car the temp gauge starts to climb to about 3/4,it also happens when the car its going uphill, so in other words if the engine is under high rpms the car starts to overheat. once its going at a steady speed it fluctuates from 1/4 to 1/2. what could be the problem, has new radiator the coolant level is good and the temp sender was also checked and replaced.
Dec 2, 2007 at 6:14 AM
