1995 Ford Mustang clutch
BURNSDL
  • 1995 FORD MUSTANG
  • V8
  • MANUAL
  • 200,000 MILES
My 95 mustang has some bad shaking, like you aren't giving it enough gas, when you try to take off in first gear. And some slight shaking between gears when releasing the clutch. What would cause this issue?
Friday, October 29th, 2010 AT 1:53 PM
WRENCHTECH
  • 20,761 POSTS
You've got a bad clutch and you will have to change the flywheel too. Make sure there are no oil leaks that could get oil on the disc before replacing it.
Make sure the pilot bearing gets changed also.
Friday, October 29th, 2010 AT 2:49 PM
BURNSDL
The entire clutch assembly, clutch cable, and the flywheel has been changed out. I do not know about the pilot bearing. What else do you suggest.
Saturday, October 30th, 2010 AT 6:03 AM
WRENCHTECH
  • 20,761 POSTS
Make sure the motor mounts are in good shape but other than that, the problem has to lie in the clutch and how the job was done.
Saturday, October 30th, 2010 AT 7:05 AM
BURNSDL
If the motor mounts are ok, could their be any possibility of this being a fuel or vacuum related issue. I have been told that I have low vacuum (15 in.), And supposed to be 20. Getting bunch of different numbers from each individual on what the vacuum should be.
Saturday, October 30th, 2010 AT 8:22 AM
WRENCHTECH
  • 20,761 POSTS
Without being there, I really have no idea what it is that your trying to describe.
Saturday, October 30th, 2010 AT 8:26 AM
BURNSDL
Ok thanks very much for your help.
Saturday, October 30th, 2010 AT 8:27 AM
