1995 Ford Mustang CAR NOISE FROM UNDER CAR
1995 FORD MUSTANG
80,000 MILES • V8 • 2WD • MANUAL
THAEMBASSY
I HAVE A 95 MUSTANG 5.0 MANUAL.. PROBLEM IS I AM GETTING A KINDA POPPING/CLUNK NOISE WHEN I PULL OFF FROM A DEAD STOP. IT WILL HAPPEN IN FIRST OR SECOND GEAR FROM A DEAD STOP.IT USUALLY MAKES THE NOISE WHEN IT IS ABOUT TO RAIN OR WHEN IT DOES RAIN.. SOUNDS LIKE IT IS COMING FROM THE MIDDLE OF THE CAR MOST OF THE TIMES.. I HEARD IT MAY BE THE MOTOR MOUNTS BUT NOT REALLY SURE.. IT SOMETIMES HAPPENS ALSO WHEN IT GET COLD OUT AROUND 40-50 DEGREES.. I HAVE NO CLUE WHAT IT IS.. DID TUNE UP, CHANGED CLUTCH, AND SHOCKS/STRUTS... NEED HELP..
Aug 28, 2008 at 12:29 AM
2CARPRO JACK
  • 11,533 POSTS
First get under there and be sure everything is tight (crossmember, mount) pry up on trans mount to see if it is bad too.Did this start after the clutch job?
Aug 28, 2008 at 12:43 AM
THAEMBASSY
NO.. THIS WAS HAPPENING BEFORE THE CLUTCH JOB.. I JUST HEAR IT MORE SINCE IT HAS BEEN RAINING EVERYDAY DUE TO THAT TROPICAL STORM..
Aug 28, 2008 at 2:01 AM
2CARPRO JACK
  • 11,533 POSTS
Check the mounts.Also check the u-joints. There isnt too much under the car mechanically that is temp sensetive.
Aug 29, 2008 at 12:33 AM
THAEMBASSY
THANKS.. IM NOT SURE WHAT THAT SOUND IS.. ILL CHECK THE U JOINTS AND EVERYTHING ELSE UNDER THERE AND ILL GET BACK WITH YOU.. THANKS. ALSO WHATS THE BEST WAY TO CHECK THE MOUNTS..
Aug 29, 2008 at 1:11 AM
2CARPRO JACK
  • 11,533 POSTS
Sagging, cracks, contact with other parys from being broken
Aug 29, 2008 at 4:12 AM
