1995 Ford Mustang CAR DOSENT START
1995 FORD MUSTANG
RICHARD RAINEY
Engine Mechanical problem
1995 Ford Mustang V8 Two Wheel Drive Automatic
i changed battery coil rotor rotor cap i smell gas and hear fuel pump when i triy to start it but it just cranks but doesnt start o it just quit running when i was driving it what can i do or try now im short on cash and got to go to work on ajob ijust got
Sep 19, 2010 at 6:26 AM
Do below and let me know what's happening
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Sep 19, 2010 at 12:11 PM
